dev:generic:toolcharts:block [2020/06/09 18:56] – raneguruprasad | dev:generic:toolcharts:block [2020/06/09 19:07] (current) – [Dialog box parameters] raneguruprasad | ||
- | **Flowchart** | ||
^Label^Appearance^Type^Explanation^ | ^Label^Appearance^Type^Explanation^ | ||
|Name|Text-box+Drop-down List|String|Name of the new block or select any existing block to redefine.| | |Name|Text-box+Drop-down List|String|Name of the new block or select any existing block to redefine.| | ||
|Description|Multi-line Text-box|String|Description for new/edited block.| | |Description|Multi-line Text-box|String|Description for new/edited block.| | ||
|Annotative Scaling|Checkbox|Bool|Can the block be scaled as per annotative scale.| | |Annotative Scaling|Checkbox|Bool|Can the block be scaled as per annotative scale.| | ||
- | |Apply uniform scale|Checkbox|Bool|self descriptive.| | + | |Apply uniform scale|Checkbox|Bool|Self descriptive.| |
- | |Allow block to explode|Checkbox|Bool|self descriptive.| | + | |Allow block to explode|Checkbox|Bool|Self descriptive.| |
|Units|Drop-down List|string|One of the various length units to be selected.| | |Units|Drop-down List|string|One of the various length units to be selected.| | ||
- | ^Basepoint||| | + | ^Basepoint| |
- | |Select in graphic area|Button|Click|Click on button to select the base point on screen.| | + | |Select |
|X|Text-Box|Decimal|Click will update the x-cord but it can be manually edited as well.| | |X|Text-Box|Decimal|Click will update the x-cord but it can be manually edited as well.| | ||
|Y|Text-Box|Decimal|Click will update the y-cord but it can be manually edited as well.| | |Y|Text-Box|Decimal|Click will update the y-cord but it can be manually edited as well.| | ||
|Y|Text-Box|Decimal|Click will update the z-cord but it can be manually edited as well.| | |Y|Text-Box|Decimal|Click will update the z-cord but it can be manually edited as well.| | ||
+ | |Preserve as separate entities|Radio Button| |Self descriptive.| | ||
