gsoc:log2020 [2020/07/19 10:44] – [Coding Period - II (July 3rd - July 31)] jedi18 | gsoc:log2020 [2020/09/02 09:11] (current) – [Coding Period - III (August 1st - August 31)] jedi18 | ||
Line 233: | Line 233: | ||
* Added group boxes to seperate entity properties. | * Added group boxes to seperate entity properties. | ||
* Added spline, polyspline and all dimension properties. | * Added spline, polyspline and all dimension properties. | ||
+ | === 20 July 2020 === | ||
+ | * Added List Input GUI Class. | ||
+ | === 21 July 2020 === | ||
+ | === 22 July 2020 === | ||
+ | === 23 July 2020 === | ||
+ | === 24 July 2020 === | ||
+ | === 25 July 2020 === | ||
+ | * Fixed minor bugs. | ||
+ | === 26 July 2020 === | ||
+ | * Added underline and strikethrough options in text dialog. | ||
+ | === 31 August 2020 === | ||
+ | * Final submisison of gsoc report. |
