gsoc:log2020 [2020/07/21 05:01] – [Coding Period - II (July 3rd - July 31)] jedi18 | gsoc:log2020 [2020/09/02 09:11] (current) – [Coding Period - III (August 1st - August 31)] jedi18 | ||
Line 235: | Line 235: | ||
=== 20 July 2020 === | === 20 July 2020 === | ||
* Added List Input GUI Class. | * Added List Input GUI Class. | ||
+ | === 21 July 2020 === | ||
+ | === 22 July 2020 === | ||
+ | === 23 July 2020 === | ||
+ | === 24 July 2020 === | ||
+ | === 25 July 2020 === | ||
+ | * Fixed minor bugs. | ||
+ | === 26 July 2020 === | ||
+ | * Added underline and strikethrough options in text dialog. | ||
+ | === 31 August 2020 === | ||
+ | * Final submisison of gsoc report. |
