gsoc:log2020 [2020/08/08 05:59] – [Coding Period - III (August 1st - August 31)] jedi18 | gsoc:log2020 [2020/09/02 09:11] (current) – [Coding Period - III (August 1st - August 31)] jedi18 | ||
Line 271: | Line 271: | ||
* Started work on context menu. | * Started work on context menu. | ||
===== Coding Period - III (August 1st - August 31) ===== | ===== Coding Period - III (August 1st - August 31) ===== | ||
- | === 01 July 2020 === | + | === 01 August |
* Added context menu manager class. | * Added context menu manager class. | ||
* Added loading of basic operation to context menu. | * Added loading of basic operation to context menu. | ||
- | === 02 July 2020 === | + | === 02 August |
* Changed initialization of context menu manager to use a static list of instances instead. | * Changed initialization of context menu manager to use a static list of instances instead. | ||
* Added few commands like last command, undo, redo, select options etc. | * Added few commands like last command, undo, redo, select options etc. | ||
- | === 03 July 2020 === | + | === 03 August |
* Divided context menu into active, inactive and selected states. | * Divided context menu into active, inactive and selected states. | ||
* Fix snap options to update changes on both toolbar and context menu. | * Fix snap options to update changes on both toolbar and context menu. | ||
* Fix undo bug. | * Fix undo bug. | ||
- | === 04 July 2020 === | + | === 04 August |
* Added meta info property to property editor. | * Added meta info property to property editor. | ||
* Added lineselect class. | * Added lineselect class. | ||
* Added layer combo box to property editor. | * Added layer combo box to property editor. | ||
- | === 05 July 2020 === | + | === 05 August |
* Added command specific context menu commands. | * Added command specific context menu commands. | ||
* Added properties for transition from current command to other commands. | * Added properties for transition from current command to other commands. | ||
* Added context menu transitions for line operation. | * Added context menu transitions for line operation. | ||
- | === 06 July 2020 === | + | === 06 August |
* Added context menu transitions for circle and few other operations. | * Added context menu transitions for circle and few other operations. | ||
* Added contextMenuOptions for other commands like arc and line switching in polyline. | * Added contextMenuOptions for other commands like arc and line switching in polyline. | ||
* Added PAN operation to pause the current active operation to allow the user to PAN. | * Added PAN operation to pause the current active operation to allow the user to PAN. | ||
- | === 07 July 2020 === | + | === 07 August |
* Fixed dock widget movement bug. | * Fixed dock widget movement bug. | ||
* Added auto adjusting of titlebar between vertical and horizontal depending on dock position. | * Added auto adjusting of titlebar between vertical and horizontal depending on dock position. | ||
+ | * Added underline and strikethrough options in text dialog. | ||
+ | === 31 August 2020 === | ||
+ | * Final submisison of gsoc report. |
