| Last revision Both sides next revision | |||
tutorial:carport [2020/06/25 03:42] flywire Created |
tutorial:carport [2020/06/25 03:47] flywire Delete discussion about old version settings |
| Line 21: | Line 21: | ||
| -Start LibreCAD - | -Start LibreCAD - | ||
| -Check your version via the Help/About menu item - the example here have been created with version 2.1.3 | -Check your version via the Help/About menu item - the example here have been created with version 2.1.3 | ||
| - | -First you might want to decide about your application preferences using [[LibreCAD_Quick_Start_Guide/ | + | -First you might want to decide about your application preferences using [[LibreCAD_Quick_Start_Guide/ |
| - | -For this example the background color has been changed to " | + | |
| -Save the default " | -Save the default " | ||
| -Check that the save was successful by Quitting LibreCAD, and restarting it. The saved file " | -Check that the save was successful by Quitting LibreCAD, and restarting it. The saved file " | ||
