| Both sides previous revision Previous revision | |||
tutorial:carport [2020/06/25 03:47] flywire Delete discussion about old version settings |
tutorial:carport [2020/06/26 04:12] flywire Markup code for images in lists |
| Line 38: | Line 38: | ||
| The first lines of any technical drawing are the '' | The first lines of any technical drawing are the '' | ||
| - | -Create a new [[Layers# | + | -Create a new [[Layers# |
| - | {{tutorials: | + | |
| -Make sure '' | -Make sure '' | ||
| Line 196: | Line 193: | ||
| -select the default layer again | -select the default layer again | ||
| - | -select the polyline tool | + | -select the polyline tool\\ {{tutorials: |
| -for each of the three beam polylines you need to | -for each of the three beam polylines you need to | ||
| -click four times at the positions to get three sides of the beam outline | -click four times at the positions to get three sides of the beam outline | ||
