| Both sides previous revision Previous revision | |||
tutorial:simple_template [2020/03/15 22:05] flywire Fix link |
tutorial:simple_template [2020/03/15 22:13] flywire Fix link |
| Line 18: | Line 18: | ||
| The page border will be displayed in the Drawing Window. Check it and save it with the following commands: File, Print Preview, set scale to 1:1, click " | The page border will be displayed in the Drawing Window. Check it and save it with the following commands: File, Print Preview, set scale to 1:1, click " | ||
| - | File, Save as A4-Landscape-Template.dxf in the template directory (refer [[https:// | + | File, Save as A4-Landscape-Template.dxf in the template directory (refer [[https:// |
| Test the template is working as expected: File, New From Template, Select A4-Landscape-Template.dxf then File, Print Preview. Click " | Test the template is working as expected: File, New From Template, Select A4-Landscape-Template.dxf then File, Print Preview. Click " | ||
| Check the other tutorials for a more complex template with a border and title block. | Check the other tutorials for a more complex template with a border and title block. | ||
