usage:line [2020/06/18 04:28] – dushyantvyasg007 | usage:line [2020/06/18 07:31] (current) – dushyantvyasg007 | ||
- | === LINE: 2 Points === | ||
- | * specify the First point (left-click). | ||
- | * specify the Second point (move cursor and left-click). | ||
- | * right-click to ' | ||
- | * type ' | ||
+ | ==== LINE: 2 Points ==== | ||
+ | * specify **first point** (left-click) | ||
Line 18: | Line 16: | ||
- | * **@60< | + | * **@60< |
- | * specify | + | * enter **angle** (see 'tool option' |
+ | * specify | ||
