dev:generic:menu [2020/06/06 14:56] – created raneguruprasad | dev:generic:menu [2020/06/06 18:26] – [Proposed Menu] raneguruprasad | ||
**Lua** | **Lua** | ||
* Run script | * Run script | ||
+ | ===== Proposed Menu ===== | ||
+ | **File** | ||
+ | * New | ||
+ | * Open | ||
+ | * Save | ||
+ | * Saveas | ||
+ | * Exit | ||
+ | **Edit** | ||
+ | * Undo | ||
+ | * Redo | ||
+ | * Cut | ||
+ | * Copy | ||
+ | * Paste | ||
+ | * Select | ||
+ | **Styles** | ||
+ | * Dimension Style | ||
+ | * Text Style | ||
+ | * Print Style | ||
+ | * Multiline Style | ||
+ | * Table Style | ||
+ | **Layers** | ||
+ | * Layer Manager | ||
+ | * Hide Layer | ||
+ | * Show All layers | ||
+ | * Freeze Layer | ||
+ | * Unfreeze All Layers | ||
+ | * Lock Layer | ||
+ | * Unlock All Layers | ||
+ | * Isolate Layer | ||
+ | * Unisolate Layer | ||
+ | * Activate Layer | ||
+ | **Draw** | ||
+ | * Line | ||
+ | * Circle | ||
+ | * Arc | ||
+ | * Ellipse | ||
+ | * Spline | ||
+ | * Polyline | ||
+ | * Dimension Align | ||
+ | * Dimension Linear | ||
+ | * Dimension Radius | ||
+ | **Modify** | ||
+ | * Move | ||
+ | * Rotate | ||
+ | * Scale | ||
+ | * Stretch | ||
+ | * Trim | ||
+ | * Offset | ||
+ | * Chamfer | ||
+ | * Fillet | ||
+ | * Extend | ||
+ | * Explode | ||
+ | **Tools** | ||
+ | * Properties | ||
+ | * Draw Order | ||
+ | * Units | ||
+ | * Custom Commands | ||
