dev:generic:toolcharts:block [2020/06/05 16:52] – raneguruprasad | dev:generic:toolcharts:block [2020/06/09 19:01] – raneguruprasad | ||
- | **Flowchart** | ||
- | In recent versions of prominent CAD programs, there is no command line interface. Instead there is a dialog box with several settings. | + | In recent versions of prominent CAD programs, there is no command line option. Instead there is a dialog box with several settings. |
+ | ===== Dialog box parameters ===== | ||
+ | |Name|Text-box+Drop-down List|String|Name of the new block or select any existing block to redefine.| | ||
+ | |Description|Multi-line Text-box|String|Description for new/edited block.| | ||
+ | |Annotative Scaling|Checkbox|Bool|Can the block be scaled as per annotative scale.| | ||
+ | |Apply uniform scale|Checkbox|Bool|self descriptive.| | ||
+ | |Allow block to explode|Checkbox|Bool|self descriptive.| | ||
+ | |Units|Drop-down List|string|One of the various length units to be selected.| | ||
+ | ^Basepoint| | ||
+ | |Select basepoint in graphic area|Button|Click|Click on button to select the base point on screen.| | ||
+ | |X|Text-Box|Decimal|Click will update the x-cord but it can be manually edited as well.| | ||
+ | |Y|Text-Box|Decimal|Click will update the y-cord but it can be manually edited as well.| | ||
+ | |Preserve as separate entities|Radio Button||self descriptive.| | ||
