dev:generic:toolcharts:block [2020/06/09 18:53] – raneguruprasad | dev:generic:toolcharts:block [2020/06/09 19:06] – [Dialog box parameters] raneguruprasad | ||
- | **Flowchart** | ||
- | ^Label^Appearance^Type^Explanation | + | |
- | |Name|Text-box+Drop-down List|String|Name of the new block or select any existing block to redefine. | + | ^Label^Appearance^Type^Explanation^ |
- | |Description|Multi-line Text-box|String|Description for new/edited block. | + | |Name|Text-box+Drop-down List|String|Name of the new block or select any existing block to redefine.| |
- | |Annotative Scaling|Checkbox|Bool|Can the block be scaled as per annotative scale. | + | |Description|Multi-line Text-box|String|Description for new/edited block.| |
- | |Apply uniform scale|Checkbox|Bool|self descriptive. | + | |Annotative Scaling|Checkbox|Bool|Can the block be scaled as per annotative scale.| |
- | |Allow block to explode|Checkbox|Bool|self descriptive. | + | |Apply uniform scale|Checkbox|Bool|Self descriptive.| |
- | |Units|Drop-down List|string|One of the various length units to be selected. | + | |Allow block to explode|Checkbox|Bool|Self descriptive.| |
- | ^Basepoint | + | |Units|Drop-down List|string|One of the various length units to be selected.| |
- | |Select in graphic area|Button||Click on button to select the base point on screen. | + | ^Basepoint| |
- | |X|Text-Box|Decimal|Click will update the x-cord but it can be manually edited as well. | + | |Select |
- | |Y|Text-Box|Decimal|Click will update the y-cord but it can be manually edited as well. | + | |X|Text-Box|Decimal|Click will update the x-cord but it can be manually edited as well.| |
- | |Y|Text-Box|Decimal|Click will update the z-cord but it can be manually edited as well. | + | |Y|Text-Box|Decimal|Click will update the y-cord but it can be manually edited as well.| |
