dev:generic:toolcharts:commoninout [2020/06/08 18:02] – raneguruprasad | dev:generic:toolcharts:commoninout [2020/06/08 18:27] – [Text Input] raneguruprasad | ||
- | Input & PointName can be obtained from variables of multilingual system. | + | Input & PointName can be obtained from variables of multilingual system. |
==== Graphic Input ==== | ==== Graphic Input ==== | ||
Line 15: | Line 15: | ||
==== Text Input ==== | ==== Text Input ==== | ||
Line 25: | Line 25: | ||
- | Input & DistanceName can be obtained from variables of multilingual system. | + | Input & DistanceName can be obtained from variables of multilingual system. |
Line 34: | Line 34: | ||
Line 44: | Line 44: | ||
- | Input & AngleName can be obtained from variables of multilingual system. | + | Input & AngleName can be obtained from variables of multilingual system. |
Line 50: | Line 50: | ||
In some cases the co-ordinates of first click, second click can be passed to this function. | In some cases the co-ordinates of first click, second click can be passed to this function. | ||
+ | ===== Integer ===== | ||
+ | ==== Initialize ==== | ||
+ | Input & IntegerName can be obtained from variables of multilingual system. e.g. '' | ||
+ | ==== Graphic Input ==== | ||
+ | * Right-click for PreviousInteger | ||
+ | ===== Decimal ===== | ||
+ | Input & DecimalName can be obtained from variables of multilingual system. e.g. '' | ||
+ | * Right-click for PreviousDecimal | ||
+ | ==== Text Input ==== | ||
+ | * Decimal | ||
===== Length Types ===== | ===== Length Types ===== | ||
- | * Decimal 14.0 | + | * Decimal: 14.0 |
- | * Architectural 1' | + | * Architectural: 1' |
+ | * Engineering: | ||
+ | * Scientific: TODO | ||
===== Angle Types ===== | ===== Angle Types ===== | ||
- | * Decimal Degrees 14.0 | + | * Decimal Degrees: 14.0 |
- | * Deg/Min/Sec 1d0' | + | * Deg/Min/Sec: 1d0' |
- | * Radian 0.000r | + | * Radian: 0.000r |
