dev:generic:toolcharts:table [2020/06/05 16:55] – raneguruprasad | dev:generic:toolcharts:table [2020/06/12 18:15] – [Dialog box parameters] raneguruprasad | ||
Line 4: | Line 4: | ||
There is no command line option. Instead there is a dialog box with several settings. | There is no command line option. Instead there is a dialog box with several settings. | ||
+ | ===== Dialog box parameters ===== | ||
+ | |Table Style|Dropdown List|String|Table style to be selected from the list.| | ||
+ | |Table Style Editor|Button|Action|Click on button to open Table Style Editor.| | ||
+ | |Insertion Method|Radio Button|Set Corners or Position|Select insertion method.| | ||
+ | |Cell Styles| | ||
+ | |First Row|Dropdown List|String|Select cell style for first row.| | ||
+ | |Second Row|Dropdown List|String|Select cell style for second row.| | ||
+ | |Other Row|Dropdown List|String|Select cell style for other row.| | ||
+ | |Rows| | ||
+ | |Numbers|Spinner|Integer|Number of rows| | ||
+ | |Height|Spinner|Decimal|height of rows| | ||
+ | |Columns| | ||
+ | |Numbers|Spinner|Integer|Number of columns| | ||
+ | |Height|Spinner|Decimal|height of columns| |
