Both sides previous revisionPrevious revision | |||
dev:v3:gui_api:dialog:dialogwidget [2020/07/09 04:46] – jedi18 | dev:v3:gui_api:dialog:dialogwidget [2020/07/09 04:46] (current) – jedi18 | ||
Line 3: | Line 3: | ||
<code cpp-qt> namespace lc::ui::api </ | <code cpp-qt> namespace lc::ui::api </ | ||
- | A Dialog widget object acts a parent widget containing all the input gui widgets. A finish button can be added which on being clicked retrieves the values of all the input guis in a table when the user is finished with the dialog. | + | A Dialog widget object acts a parent widget containing all the input gui widgets. A finish button can be added which on being clicked retrieves the values of all the input guis in a table when the user is finished with the dialog. This table is passed in as a parameter to all the finish callbacks added to the dialog widget. |
