dev:v3:gui_api:dialog:inputgui1 [2020/07/09 06:08] – jedi18 | dev:v3:gui_api:dialog:inputgui1 [2020/07/09 06:34] – jedi18 | ||
Line 138: | Line 138: | ||
=== Examples === | === Examples === | ||
- | * <code lua> angle1: | + | * <code lua> angle1: |
Line 232: | Line 232: | ||
* <code lua> local isChecked = check1: | * <code lua> local isChecked = check1: | ||
* <code lua> check1: | * <code lua> check1: | ||
+ | ===== ComboBox GUI Class ===== | ||
+ | [[https:// | ||
+ | <code cpp-qt> namespace lc::ui::api </ | ||
+ | The ComboBox GUI class is used to add a combobox to the dialog widget. Callbacks can be added to the checkbox which is called when a element is selected, the name of the selected element is passed as a parameter to the callback. | ||
+ | ==== Constructor ==== | ||
+ | === Description === | ||
+ | Constructs an combobox gui widget | ||
+ | === Examples === | ||
+ | * <code lua> local combo1 = gui.ComboBoxGUI(" | ||
+ | ==== Add Callback ==== | ||
+ | Add a callback to be called whenever selects an element from the combobox.Passes in a string representing the name of the selected element in the combobox. | ||
+ | * <code lua> combo1: | ||
+ | ==== Get and Set Values ==== | ||
+ | Used to get the current element string of the combobox widget or set it to a desired element. If the user attempts to set an element that does not exist in the combobox, nothing happens. | ||
+ | Element can also be set by specifying the index of the element to be selected. | ||
+ | * <code lua> local val = combo1: | ||
+ | ==== Add Item ==== | ||
+ | Add an item to the combobox, if index is not specified it is added to the end of the combobox list. | ||
