dev:v3:gui_api:menu:main_window [2020/07/06 05:42] – [Remove Menu] jedi18 | dev:v3:gui_api:menu:main_window [2020/07/06 14:34] – [Description] jedi18 | ||
Line 11: | Line 11: | ||
- | * <code cpp-qt> lc:: | + | * Menu Name |
Line 37: | Line 30: | ||
- | * <code cpp-qt> lc:: | + | * Menu Label |
- | * Get menu by name/ | + | * Menu Position (Starting from 0 on the left most menu) |
- | - Menu Name - **Name/Label** of the menu to be returned. | + | |
Line 69: | Line 50: | ||
- | * <code cpp-qt> | + | |
- | | + | * Menu Position - int (Starting from 0 as the left most menu) |
+ | ==== Examples ==== | ||
+ | * <code lua> mainWindow: | ||
+ | ===== Find Menu Item ===== | ||
+ | ==== Description ==== | ||
+ | Find and return the first menu item found of the given **label**/ | ||
* Parameters :- | * Parameters :- | ||
- | - Menu Name - **Name/ | + | - Menu Item Name - **Name/ |
+ | * Returns :- | ||
+ | - **Pointer to menu item** found of the given label. | ||
- | * <code cpp-qt> | + | * <code cpp-qt> |
+ | - **Pointer to menu item** found of the given object name. | ||
+ | * <code lua> local item1 = mainWindow: | ||
+ | * <code lua> local item2 = mainWindow: | ||
