dev:v3:gui_api:menu:main_window [2020/07/06 05:44] – [Examples] jedi18 | dev:v3:gui_api:menu:main_window [2020/07/06 14:36] – [Description] jedi18 | ||
Line 11: | Line 11: | ||
- | * <code cpp-qt> lc:: | + | * Menu Name - //string// |
Line 37: | Line 30: | ||
- | * <code cpp-qt> lc:: | + | * Menu Label - string |
- | * Get menu by name/ | + | * Menu Position |
- | - Menu Name - **Name/Label** of the menu to be returned. | + | |
Line 69: | Line 50: | ||
- | * <code cpp-qt> void removeMenu(const char* menuLabel) </ | + | * Menu Label - string |
- | * Remove menu of the given name/ | + | * Menu Position |
- | * <code cpp-qt> void removeMenu(int position) </ | + | |
Line 88: | Line 61: | ||
===== Find Menu Item ===== | ===== Find Menu Item ===== | ||
+ | ==== Description ==== | ||
+ | Find and return the first menu item found of the given **label**/ | ||
+ | * <code cpp-qt> lc:: | ||
+ | * Find menu item of the given label | ||
+ | * Parameters :- | ||
+ | - Menu Item Name - **Name/ | ||
+ | * Returns :- | ||
+ | - **Pointer to menu item** found of the given label. | ||
+ | * Find menu item of the given qt object name. | ||
+ | - Object name - **Qt object name** of the menu item to be found. | ||
+ | - **Pointer to menu item** found of the given object name. | ||
+ | ==== Examples ==== | ||
+ | * <code lua> local item1 = mainWindow: | ||
+ | * <code lua> local item2 = mainWindow: | ||
