dev:v3:gui_api:menu:main_window [2020/07/06 05:44] – [Examples] jedi18 | dev:v3:gui_api:menu:main_window [2020/07/06 14:38] – jedi18 | ||
Line 11: | Line 11: | ||
- | * <code cpp-qt> lc:: | + | * Menu Name - //string// |
Line 37: | Line 30: | ||
- | Return pointer to menu of the given name or position present in the menu bar. | + | Return pointer to menu of the given **name** or **position** present in the menu bar. Returns nullptr if not present. |
Line 67: | Line 48: | ||
Line 88: | Line 61: | ||
===== Find Menu Item ===== | ===== Find Menu Item ===== | ||
+ | ==== Description ==== | ||
+ | Find and return the first menu item found of the given **label**/ | ||
+ | * Menu Item Label - //string// | ||
+ | * Menu Item Qt Object Name - //string// | ||
+ | ==== Examples ==== | ||
+ | * <code lua> local item1 = mainWindow: | ||
+ | * <code lua> local item2 = mainWindow: | ||
