dev:v3:gui_api:menu:main_window [2020/07/06 05:53] – [Description] jedi18 | dev:v3:gui_api:menu:main_window [2020/07/06 14:37] – [Description] jedi18 | ||
Line 11: | Line 11: | ||
- | * <code cpp-qt> lc:: | + | * Menu Name - //string// |
Line 37: | Line 30: | ||
Line 67: | Line 48: | ||
Line 95: | Line 68: | ||
