dev:v3:gui_api:menu:main_window [2020/07/06 14:27] – [Description] jedi18 | dev:v3:gui_api:menu:main_window [2020/07/06 14:38] – jedi18 | ||
Line 11: | Line 11: | ||
Line 29: | Line 30: | ||
- | Return pointer to menu of the given name or position present in the menu bar. | + | Return pointer to menu of the given **name** or **position** present in the menu bar. Returns nullptr if not present. |
Line 59: | Line 48: | ||
Line 87: | Line 68: | ||
