dev:v3:gui_api:menu:main_window [2020/07/06 14:28] – [Description] jedi18 | dev:v3:gui_api:menu:main_window [2020/07/06 14:34] – [Description] jedi18 | ||
Line 12: | Line 12: | ||
Will not add if another menu of the same label already exists in the menu bar. | Will not add if another menu of the same label already exists in the menu bar. | ||
- | Note :- Menu of same label may exist in a menu inside a menu of the menu bar i.e. more than one level away from the menu bar. | + | \\ Note :- Menu of same label may exist in a menu inside a menu of the menu bar i.e. more than one level away from the menu bar. |
- | * Menu Name | + | * Menu Name - string |
- | * Pointer to Menu GUI object | + | * Pointer to Menu GUI object - menu gui object |
- | * <code cpp-qt> lc:: | + | * Menu Label |
- | * Get menu by name/ | + | * Menu Position (Starting from 0 on the left most menu) |
- | - Menu Name - **Name/Label** of the menu to be returned. | + | |
Line 62: | Line 50: | ||
- | * <code cpp-qt> void removeMenu(const char* menuLabel) </ | + | * Menu Label - string |
- | * Remove menu of the given name/ | + | * Menu Position |
- | * <code cpp-qt> void removeMenu(int position) </ | + | |
