dev:v3:gui_api:menu:main_window [2020/07/06 14:28] – [Description] jedi18 | dev:v3:gui_api:menu:main_window [2020/07/06 14:37] – jedi18 | ||
Line 12: | Line 12: | ||
Will not add if another menu of the same label already exists in the menu bar. | Will not add if another menu of the same label already exists in the menu bar. | ||
- | Note :- Menu of same label may exist in a menu inside a menu of the menu bar i.e. more than one level away from the menu bar. | + | \\ Note :- Menu of same label may exist in a menu inside a menu of the menu bar i.e. more than one level away from the menu bar. |
Line 62: | Line 50: | ||
Line 88: | Line 68: | ||
