dev:v3:gui_api:menu:main_window [2020/07/06 14:29] – [Description] jedi18 | dev:v3:gui_api:menu:main_window [2020/07/06 14:38] – jedi18 | ||
Line 12: | Line 12: | ||
Will not add if another menu of the same label already exists in the menu bar. | Will not add if another menu of the same label already exists in the menu bar. | ||
- | //Note :- Menu of same label may exist in a menu inside a menu of the menu bar i.e. more than one level away from the menu bar. | + | \\ Note :- Menu of same label may exist in a menu inside a menu of the menu bar i.e. more than one level away from the menu bar. |
- | Return pointer to menu of the given name or position present in the menu bar. | + | Return pointer to menu of the given **name** or **position** present in the menu bar. Returns nullptr if not present. |
Line 60: | Line 48: | ||
Line 88: | Line 68: | ||
