dev:v3:gui_api:menu:main_window [2020/07/06 14:32] – [Description] jedi18 | dev:v3:gui_api:menu:main_window [2020/07/06 14:35] – [Description] jedi18 | ||
- | | + | * Menu Name - string |
- | | + | * Pointer to Menu GUI object |
Line 32: | Line 32: | ||
Return pointer to menu of the given name or position present in the menu bar. Returns nullptr if not present. | Return pointer to menu of the given name or position present in the menu bar. Returns nullptr if not present. | ||
- | * Menu Label | + | * Menu Label - string |
- | * Menu Position (Starting from 0 on the left most menu) | + | * Menu Position |
Line 50: | Line 50: | ||
- | * <code cpp-qt> void removeMenu(const char* menuLabel) </ | + | * Menu Label - string |
- | * Remove menu of the given name/ | + | * Menu Position |
- | * <code cpp-qt> void removeMenu(int position) </ | + | |
