dev:v3:gui_api:menu:main_window [2020/07/06 14:33] – [Description] jedi18 | dev:v3:gui_api:menu:main_window [2020/07/06 14:38] – jedi18 | ||
- | Return pointer to menu of the given name or position present in the menu bar. Returns nullptr if not present. | + | Return pointer to menu of the given **name** or **position** present in the menu bar. Returns nullptr if not present. |
- | * Menu Label | + | * Menu Label - //string// |
- | * Menu Position (Starting from 0 on the left most menu) | + | * Menu Position |
Line 48: | Line 48: | ||
Line 76: | Line 68: | ||
