dev:v3:gui_api:menu:main_window [2020/07/06 14:34] – [Description] jedi18 | dev:v3:gui_api:menu:main_window [2020/07/06 14:38] – jedi18 | ||
- | * Menu Name - string | + | * Menu Name - //string// |
- | * Pointer to Menu GUI object - menu gui object | + | * Pointer to Menu GUI object - //menu gui object// |
- | Return pointer to menu of the given name or position present in the menu bar. Returns nullptr if not present. | + | Return pointer to menu of the given **name** or **position** present in the menu bar. Returns nullptr if not present. |
- | * Menu Label | + | * Menu Label - //string// |
- | * Menu Position (Starting from 0 on the left most menu) | + | * Menu Position |
Line 48: | Line 48: | ||
- | * Menu Label - string | + | * Menu Label - //string// |
- | * Menu Position - int (Starting from 0 as the left most menu) | + | * Menu Position - //int// (Starting from 0 as the left most menu) |
Line 68: | Line 68: | ||
