Both sides previous revisionPrevious revision | Next revisionBoth sides next revision | ||
dev:v3:gui_api:menu:main_window [2020/07/06 14:37] – jedi18 | dev:v3:gui_api:menu:main_window [2020/07/06 14:37] – [Description] jedi18 | ||
Line 48: | Line 48: | ||
* Menu Label - //string// | * Menu Label - //string// |
