dev:v3:gui_api:menu:main_window [2020/07/06 14:37] – jedi18 | dev:v3:gui_api:menu:main_window [2020/07/06 14:39] – [Main Window Menu GUI API Functions] jedi18 | ||
====== Main Window Menu GUI API Functions ====== | ====== Main Window Menu GUI API Functions ====== | ||
[[https:// | [[https:// | ||
- | Return pointer to menu of the given name or position present in the menu bar. Returns nullptr if not present. | + | Return pointer to menu of the given **name** or **position** present in the menu bar. Returns nullptr if not present. |
* Menu Label - //string// | * Menu Label - //string// | ||
Line 48: | Line 48: | ||
