dev:v3:gui_api:menu:main_window
dev:v3:gui_api:menu:main_window [2020/07/06 14:35] – [Description] jedi18dev:v3:gui_api:menu:main_window [2020/07/06 14:39] (current) – [Main Window Menu GUI API Functions] jedi18
 ====== Main Window Menu GUI API Functions ====== ====== Main Window Menu GUI API Functions ======
 [[https://github.com/LibreCAD/LibreCAD_3/blob/master/lcUI/mainwindow.h|Github Link]] [[https://github.com/LibreCAD/LibreCAD_3/blob/master/lcUI/mainwindow.h|Github Link]]
-<code cpp-qt> namespace lc::ui::api </code>+<code lua> namespace lc::ui::api </code>
Line 14: Line 14:
 \\ Note :- Menu of same label may exist in a menu inside a menu of the menu bar i.e. more than one level away from the menu bar. \\ Note :- Menu of same label may exist in a menu inside a menu of the menu bar i.e. more than one level away from the menu bar.
-  * Menu Name - string +  * Menu Name - //string//
-  * Pointer to Menu GUI object - menu gui object+  * Pointer to Menu GUI object - //menu gui object//
 ==== Examples ==== ==== Examples ====
Line 30: Line 30:
 ==== Description ==== ==== Description ====
-Return pointer to menu of the given name or position present in the menu bar. Returns nullptr if not present.+Return pointer to menu of the given **name** or **position** present in the menu bar. Returns nullptr if not present.
-  * Menu Label - string +  * Menu Label - //string//
-  * Menu Position - int (Starting from 0 on the left most menu)+  * Menu Position - //int// (Starting from 0 on the left most menu)
Line 48: Line 48:
-Remove menu of the given name or at the given position from the menu bar. Does nothing if menu does not exist in the menu bar.+Remove menu of the given **name** or at the given **position** from the menu bar. Does nothing if menu does not exist in the menu bar.
-  * Menu Position - int (Starting from 0 as the left most menu)+  * Menu Position - //int// (Starting from 0 as the left most menu)
Line 68: Line 68:
 Find and return the first menu item found of the given **label**/**object name** present in any of the menus recursively (menu bar as well as menus inside other menus). Find and return the first menu item found of the given **label**/**object name** present in any of the menus recursively (menu bar as well as menus inside other menus).
-  * <code cpp-qt> lc::ui::api::MenuItem* findMenuItem(std::string label) </code>   +  * Menu Item Label - //string//
-     * Find menu item of the given label +  * Menu Item Qt Object Name - //string//
-     * Parameters :- +
-       - Menu Item Name - **Name/Label** of the menu item to be found. +
-     * Returns :- +
-       - **Pointer to menu item** found of the given label. +
-  * <code cpp-qt> lc::ui::api::MenuItem* findMenuItemByObjectName(std::string objectName) </code>   +
-     * Find menu item of the given qt object name. +
-     * Parameters :- +
-       - Object name - **Qt object name** of the menu item to be found. +
-     * Returns :- +
-       - **Pointer to menu item** found of the given object name.+
dev/v3/gui_api/menu/main_window.1594046107.txt.gz · Last modified: 2020/07/06 14:35 by jedi18
