Trace: • main_window
dev:v3:gui_api:menu:main_window
dev:v3:gui_api:menu:main_window [2020/07/06 14:37] – jedi18dev:v3:gui_api:menu:main_window [2020/07/06 14:39] (current) – [Main Window Menu GUI API Functions] jedi18
 ====== Main Window Menu GUI API Functions ====== ====== Main Window Menu GUI API Functions ======
 [[https://github.com/LibreCAD/LibreCAD_3/blob/master/lcUI/mainwindow.h|Github Link]] [[https://github.com/LibreCAD/LibreCAD_3/blob/master/lcUI/mainwindow.h|Github Link]]
-<code cpp-qt> namespace lc::ui::api </code>+<code lua> namespace lc::ui::api </code>
Line 30: Line 30:
 ==== Description ==== ==== Description ====
-Return pointer to menu of the given name or position present in the menu bar. Returns nullptr if not present.+Return pointer to menu of the given **name** or **position** present in the menu bar. Returns nullptr if not present.
   * Menu Label - //string//   * Menu Label - //string//
Line 48: Line 48:
-Remove menu of the given name or at the given position from the menu bar. Does nothing if menu does not exist in the menu bar.+Remove menu of the given **name** or at the given **position** from the menu bar. Does nothing if menu does not exist in the menu bar.
dev/v3/gui_api/menu/main_window.1594046241.txt.gz · Last modified: 2020/07/06 14:37 by jedi18
