dev:v3:gui_api:menu:main_window [2020/07/06 14:30] – [Description] jedi18 | dev:v3:gui_api:menu:main_window [2020/07/06 14:39] (current) – [Main Window Menu GUI API Functions] jedi18 | ||
====== Main Window Menu GUI API Functions ====== | ====== Main Window Menu GUI API Functions ====== | ||
[[https:// | [[https:// | ||
- | Return pointer to menu of the given name or position present in the menu bar. | + | Return pointer to menu of the given **name** or **position** present in the menu bar. Returns nullptr if not present. |
Line 60: | Line 48: | ||
Line 88: | Line 68: | ||
