gsoc:log2020 [2020/07/19 10:43] – [Coding Period - II (July 3rd - July 31)] jedi18 | gsoc:log2020 [2020/08/14 13:10] – [Coding Period - III (August 1st - August 31)] jedi18 | ||
Line 230: | Line 230: | ||
* Changed creation of property widgets. | * Changed creation of property widgets. | ||
* Added properties for a few classes like line, | * Added properties for a few classes like line, | ||
+ | === 19 July 2020 === | ||
+ | * Added group boxes to seperate entity properties. | ||
+ | * Added spline, polyspline and all dimension properties. | ||
+ | === 20 July 2020 === | ||
+ | * Added List Input GUI Class. | ||
+ | === 21 July 2020 === | ||
+ | === 22 July 2020 === | ||
+ | === 23 July 2020 === | ||
+ | === 24 July 2020 === | ||
+ | === 25 July 2020 === | ||
+ | * Fixed minor bugs. | ||
+ | === 26 July 2020 === | ||
+ | * Added ArcWithSEA for arcoperations. |
