gsoc:log2020 [2020/07/23 04:38] – [Coding Period - II (July 3rd - July 31)] jedi18 | gsoc:log2020 [2020/08/17 11:07] – [Coding Period - III (August 1st - August 31)] jedi18 | ||
Line 241: | Line 241: | ||
* Added point highlighting for list gui widget. | * Added point highlighting for list gui widget. | ||
* Created LWVertexGroup class for holding polyline vertices in the properties widget. | * Created LWVertexGroup class for holding polyline vertices in the properties widget. | ||
+ | === 23 July 2020 === | ||
+ | === 24 July 2020 === | ||
+ | === 25 July 2020 === | ||
+ | * Fixed minor bugs. | ||
+ | === 26 July 2020 === | ||
+ | * Entity creation using deserialized json data. |
