gsoc:log2020 [2020/07/25 11:18] – [Coding Period - II (July 3rd - July 31)] jedi18 | gsoc:log2020 [2020/08/17 11:07] – [Coding Period - III (August 1st - August 31)] jedi18 | ||
Line 247: | Line 247: | ||
=== 24 July 2020 === | === 24 July 2020 === | ||
* Replaced group box with tree widget in the property editor. | * Replaced group box with tree widget in the property editor. | ||
+ | === 25 July 2020 === | ||
+ | * Fixed minor bugs. | ||
+ | === 26 July 2020 === | ||
+ | * Entity creation using deserialized json data. |
