gsoc:log2020 [2020/07/26 17:24] – [Coding Period - II (July 3rd - July 31)] jedi18 | gsoc:log2020 [2020/08/14 13:10] – [Coding Period - III (August 1st - August 31)] jedi18 | ||
Line 253: | Line 253: | ||
* Tried to figure out seg fault on travis build but not on pc. | * Tried to figure out seg fault on travis build but not on pc. | ||
* Started refactoring button and checkbox part of input gui. | * Started refactoring button and checkbox part of input gui. | ||
+ | * Added ArcWithSEA for arcoperations. |
