gsoc:log2020 [2020/07/30 05:41] – [Coding Period - II (July 3rd - July 31)] jedi18 | gsoc:log2020 [2020/08/24 06:01] – [Coding Period - III (August 1st - August 31)] jedi18 | ||
Line 260: | Line 260: | ||
* Fixed minor arc bug, added point properties. | * Fixed minor arc bug, added point properties. | ||
* Added copy paste functionality for input guis through context menu. | * Added copy paste functionality for input guis through context menu. | ||
+ | * Added context menu transitions for text operation |
