gsoc:log2020 [2020/07/30 05:43] – [Coding Period - II (July 3rd - July 31)] jedi18 | gsoc:log2020 [2020/08/20 10:01] – [Coding Period - III (August 1st - August 31)] jedi18 | ||
Line 264: | Line 264: | ||
* Add column to make property editor table-like, also added some styling. | * Add column to make property editor table-like, also added some styling. | ||
* Attempted to fix build constants bug with help from mentors. | * Attempted to fix build constants bug with help from mentors. | ||
+ | * Added entity properties for text. |
