gsoc:log2020 [2020/07/30 05:41] – [Coding Period - II (July 3rd - July 31)] jedi18 | gsoc:log2020 [2020/09/02 09:11] (current) – [Coding Period - III (August 1st - August 31)] jedi18 | ||
Line 260: | Line 260: | ||
* Fixed minor arc bug, added point properties. | * Fixed minor arc bug, added point properties. | ||
* Added copy paste functionality for input guis through context menu. | * Added copy paste functionality for input guis through context menu. | ||
+ | * Added underline and strikethrough options in text dialog. | ||
+ | === 31 August 2020 === | ||
+ | * Final submisison of gsoc report. |
