gsoc:log2020 [2020/08/03 04:09] – [Coding Period - III (August 1st - August 31)] jedi18 | gsoc:log2020 [2020/08/30 16:22] – [Coding Period - III (August 1st - August 31)] jedi18 | ||
Line 271: | Line 271: | ||
* Started work on context menu. | * Started work on context menu. | ||
===== Coding Period - III (August 1st - August 31) ===== | ===== Coding Period - III (August 1st - August 31) ===== | ||
- | === 01 July 2020 === | + | === 01 August |
* Added context menu manager class. | * Added context menu manager class. | ||
* Added loading of basic operation to context menu. | * Added loading of basic operation to context menu. | ||
- | === 02 July 2020 === | + | === 02 August |
* Changed initialization of context menu manager to use a static list of instances instead. | * Changed initialization of context menu manager to use a static list of instances instead. | ||
* Added few commands like last command, undo, redo, select options etc. | * Added few commands like last command, undo, redo, select options etc. | ||
+ | * Added underline and strikethrough options in text dialog. |
