gsoc:log2020 [2020/08/14 13:10] – [Coding Period - III (August 1st - August 31)] jedi18 | gsoc:log2020 [2020/08/30 16:22] – [Coding Period - III (August 1st - August 31)] jedi18 | ||
Line 311: | Line 311: | ||
=== 13 August 2020 === | === 13 August 2020 === | ||
* Added ArcWithSEA for arcoperations. | * Added ArcWithSEA for arcoperations. | ||
+ | * Added underline and strikethrough options in text dialog. |
