gsoc:log2020 [2020/08/17 11:07] – [Coding Period - III (August 1st - August 31)] jedi18 | gsoc:log2020 [2020/08/30 16:22] – [Coding Period - III (August 1st - August 31)] jedi18 | ||
Line 321: | Line 321: | ||
* Created PR for arc_operations | * Created PR for arc_operations | ||
* Entity creation using deserialized json data. | * Entity creation using deserialized json data. | ||
+ | * Added underline and strikethrough options in text dialog. |
