gsoc:log2022 [2022/07/23 20:52] – [Week 6 (July 18 - July 24)] cristik24 | gsoc:log2022 [2022/09/10 18:56] (current) – [Week 9 (August 8 - August 14)] cristik24 | ||
Line 101: | Line 101: | ||
July 22 - Found why path weren' | July 22 - Found why path weren' | ||
July 23 - Qt's application file path is succesful for the lcUILua paths, but for settings ones in lckernel, I need to implement some extra methods to get the path from | July 23 - Qt's application file path is succesful for the lcUILua paths, but for settings ones in lckernel, I need to implement some extra methods to get the path from | ||
+ | July 24 - Created a Method from lcUI to get the path from. This way, lckernel can get the path with the qt library. However, this provokes a deadlock! | ||
+ | ===== Week 7 (July 25 - July 31) ===== | ||
+ | July 25 - Instead of having the method in lcUI i've moved to lckernel, to not create the deadlock. I'm having some trouble due to having to use the object. I've noticed that there is an " | ||
+ | July 26 - investigation in the " | ||
+ | July 27 - In a hesitation about how to proceed because of "Even if I set the correct path to the settings from the mainwindow.h , that wouldn' | ||
+ | July 28 - I've managed to add the absolute path for the settings directly in lcUI/ | ||
+ | July 29 - Tried different ways to change res.cpp in lcviewernoqt so it has the absolute path from lcUI (Right now it has c++ error c2373 redefinition different type modifiers ) | ||
+ | July 30 - day off | ||
+ | July 31 - day off | ||
+ | ===== Week 8 (August 1 - August 8) ===== | ||
+ | August 1 - day off | ||
+ | August 2 - Passed all the scripts to the format in yaml format and began testing it for Github Actions | ||
+ | August 3 - Tried out more ways to add the path to lcviewernoqt, | ||
+ | August 4 - Investigated more in depth the code, and tried out more ways to get it working (still failure compilating) | ||
+ | August 5 - Managed to add a code to modify the path from lcUI, but right now, even if it compiles , doasn' | ||
+ | August 6 - Found a way using functions instead of directly modifying. Tried to verify with the appImage, but seems a file stopped being created. | ||
+ | August 7 - Managed to get the snap and AppImage functional ( At the beginning the painter is not working, but when opening a new screen, the painter works) | ||
+ | ===== Week 9 (August 8 - August 14) ===== | ||
+ | August 8 - Solved the issue with the painter creating before the path change | ||
+ | August 9 - day off | ||
+ | August 10 - Restructured the github yaml towards using scripts with the commands inside instead of using the commands directly | ||
+ | August 11 - Solving various issues with the yaml (there are still some) | ||
+ | August 12 - More little changes solved (It still doasn' | ||
+ | August 13 - Day off | ||
+ | August 14 - Day off | ||
+ | === Week 11 ( August 22 - August 28 ) === | ||
+ | August 22 - day off | ||
+ | August 25 - day off | ||
+ | August 26 - day off | ||
+ | August 27 - day off | ||
+ | September 3 - It looks like the error is not from the packaging, so I'm good to write some documentation. | ||
+ | === Week 13 ( September 5- September 11) === | ||
+ | September 6 - Began writing the CI/CD documentation | ||
+ | September 7 - Finished the documentation and transformed intro markdown to put it on the central wiki | ||
+ | September 8 - Ups! I added it on the footer of the Continuous integration page, didn't know it was global. I moved it intro the normal CI page of the wiki | ||
+ | September 10 - Began writing the final report | ||
