gsoc:log2022 [2022/08/05 21:55] – [Week 8 (August 1 - August 8)] cristik24 | gsoc:log2022 [2022/09/02 21:41] – [Week 9 (August 8 - August 14)] cristik24 | ||
Line 133: | Line 133: | ||
August 4 - Investigated more in depth the code, and tried out more ways to get it working (still failure compilating) | August 4 - Investigated more in depth the code, and tried out more ways to get it working (still failure compilating) | ||
- | August 5 - Managed to add a code to modify the path from lcUI, but right now, even if it compiles | + | August 5 - Managed to add a code to modify the path from lcUI, but right now, even if it compiles , doasn' |
+ | August 6 - Found a way using functions instead of directly modifying. Tried to verify with the appImage, but seems a file stopped being created. | ||
+ | August 7 - Managed to get the snap and AppImage functional ( At the beginning the painter is not working, but when opening a new screen, the painter works) | ||
+ | ===== Week 9 (August 8 - August 14) ===== | ||
+ | August 8 - Solved the issue with the painter creating before the path change | ||
+ | August 9 - day off | ||
+ | August 10 - Restructured the github yaml towards using scripts with the commands inside instead of using the commands directly | ||
+ | August 11 - Solving various issues with the yaml (there are still some) | ||
+ | August 12 - More little changes solved (It still doasn' | ||
+ | August 13 - Day off | ||
+ | August 14 - Day off | ||
+ | === Week 11 ( August 22 - August 28 ) === | ||
+ | August 22 - day off | ||
+ | August 25 - day off | ||
+ | August 26 - day off | ||
+ | August 27 - day off | ||
+ | September 3 - | ||
+ | September 4 - | ||
