Both sides previous revisionPrevious revision | Last revisionBoth sides next revision | ||
gsoc:log2022 [2022/08/23 20:34] – cristik24 | gsoc:log2022 [2022/09/02 21:41] – [Week 9 (August 8 - August 14)] cristik24 | ||
Line 171: | Line 171: | ||
August 21 - Strange error when installing Librecad on Windows VMs. | August 21 - Strange error when installing Librecad on Windows VMs. | ||
- | === Week 11 ( August 22 - August 28 ) | + | === Week 11 ( August 22 - August 28 ) === |
August 22 - day off | August 22 - day off | ||
August 23 - The errors looks related to openGL, though it's strange. I don't know if this error needs correction or if it's expected librecad to fail in VM with such old openGL versions | August 23 - The errors looks related to openGL, though it's strange. I don't know if this error needs correction or if it's expected librecad to fail in VM with such old openGL versions | ||
+ | August 25 - day off | ||
+ | August 26 - day off | ||
+ | August 27 - day off | ||
+ | September 3 - | ||
+ | September 4 - | ||
