gsoc:log2022
gsoc:log2022 [2022/08/05 21:54] – [Week 8 (August 1 - August 8)] cristik24gsoc:log2022 [2022/09/10 18:56] (current) – [Week 9 (August 8 - August 14)] cristik24
Line 131: Line 131:
 August 3 - Tried out more ways to add the path to lcviewernoqt, errors of missing links, namespace errors, variable defined more than needed... August 3 - Tried out more ways to add the path to lcviewernoqt, errors of missing links, namespace errors, variable defined more than needed...
-August 4 - Managed to add a code to modify the path from lcUI, but right now, even if it compiles now, doasn't change the path (some kind of bug, or the design is not correct+August 4 - Investigated more in depth the code, and tried out more ways to get it working (still failure compilating)
 +August 5 - Managed to add a code to modify the path from lcUI, but right now, even if it compiles , doasn't change the path (some kind of bug, or the design is not correct
 +August 6 - Found a way using functions instead of directly modifying. Tried to verify with the appImage, but seems a file stopped being created.
 +August 7 - Managed to get the snap and AppImage functional ( At the beginning the painter is not working, but when opening a new screen, the painter works)
 +===== Week 9 (August 8 - August 14) =====
 +August 8 - Solved the issue with the painter creating before the path change
 +August 9 - day off
 +August 10 - Restructured the github yaml towards using scripts with the commands inside instead of using the commands directly
 +August 11 - Solving various issues with the yaml (there are still some)
 +August 12 - More little changes solved (It still doasn't work)
 +August 13 - Day off
 +August 14 - Day off
 +=== Week 10 (August 15 - August 21) =====
 +August 15 - solved winqt action problems
 +August 16 - Modified YAML with github variables
 +August 17 - Solved small errors in the scripts ( mostly related to paths and and cloning recursively)
 +August 18 - Windows artifact works, now working on appimage and correcting errors with libdrfx library (it's not found)
 +August 19 - Managed to get the AppImage, Also began working on modifications of the snapcraft script. Managed to get the snap too!
 +August 20 - Modified the AppImage and Snapcraft to Ubuntu 20.04 as 18.04 was going to be deprecated. Now all artifacts work!
 +August 21 - Strange error when installing Librecad on Windows VMs.
 +=== Week 11 ( August 22 - August 28 ) ===
 +August 22 - day off
 +August 23 - The errors looks related to openGL, though it's strange. I don't know if this error needs correction or if it's expected librecad to fail in VM with such old openGL versions
 +August 24 - PR open and began codefactoring
 +August 25 - day off
 +August 26 - day off
 +August 27 - day off
 +August 28 -deleting unneded scripts. Changing the names of the ones still used. used the submodule option in checkout action instead of using it manually
 +=== Week 12 ( August 29 - September 4) ===
 +August 29 - Trying out LUACMDINTERFACE ON, to see if it builds now
 +August 30 - Trying to build a LC3 debug on github actions. Error on a path of libpng when building the project. libpng is installed by conan.
 +August 31 - Tried to build LC3 debug in my computer instead of github actions. Same error of libpng as before
 +September 1 - Finally got the debug version of LC3 by building in my local computer. Had to manually change the name of a conan package folder (libpng) . It works correctly (no issue when tried)
 +September 2 - Tried some more times to execute diferent releases of LC3 on windows, and filmed them. Using DR.Memory didn't say anything to see the error.
 +September 3 - It looks like the error is not from the packaging, so I'm good to write some documentation.
 +=== Week 13 ( September 5- September 11) ===
 +September 6 - Began writing the CI/CD documentation
 +September 7 - Finished the documentation and transformed intro markdown to put it on the central wiki
 +September 8 - Ups! I added it on the footer of the Continuous integration page, didn't know it was global. I moved it intro the normal CI page of the wiki
 +September 10 - Began writing the final report
gsoc/log2022.1659736474.txt.gz · Last modified: 2022/08/05 21:54 by cristik24
