gsoc:log2022 [2022/08/07 22:58] – [Week 8 (August 1 - August 8)] cristik24 | gsoc:log2022 [2022/09/10 18:56] (current) – [Week 9 (August 8 - August 14)] cristik24 | ||
Line 138: | Line 138: | ||
August 7 - Managed to get the snap and AppImage functional ( At the beginning the painter is not working, but when opening a new screen, the painter works) | August 7 - Managed to get the snap and AppImage functional ( At the beginning the painter is not working, but when opening a new screen, the painter works) | ||
+ | ===== Week 9 (August 8 - August 14) ===== | ||
+ | August 8 - Solved the issue with the painter creating before the path change | ||
+ | August 9 - day off | ||
+ | August 10 - Restructured the github yaml towards using scripts with the commands inside instead of using the commands directly | ||
+ | August 11 - Solving various issues with the yaml (there are still some) | ||
+ | August 12 - More little changes solved (It still doasn' | ||
+ | August 13 - Day off | ||
+ | August 14 - Day off | ||
+ | === Week 11 ( August 22 - August 28 ) === | ||
+ | August 22 - day off | ||
+ | August 25 - day off | ||
+ | August 26 - day off | ||
+ | August 27 - day off | ||
+ | September 3 - It looks like the error is not from the packaging, so I'm good to write some documentation. | ||
+ | === Week 13 ( September 5- September 11) === | ||
+ | September 6 - Began writing the CI/CD documentation | ||
+ | September 7 - Finished the documentation and transformed intro markdown to put it on the central wiki | ||
+ | September 8 - Ups! I added it on the footer of the Continuous integration page, didn't know it was global. I moved it intro the normal CI page of the wiki | ||
+ | September 10 - Began writing the final report | ||
