gsoc:plan2022 [2022/06/11 11:59] – cristik24 | gsoc:plan2022 [2022/06/11 12:01] – [Packaging the Windows install (Week 1-2)] cristik24 | ||
Line 3: | Line 3: | ||
Finding a way to use cmake to emulate Visual' | Finding a way to use cmake to emulate Visual' | ||
- | =====Coding of the Linux script | + | =====Packaging |
- | I have only built the project for windows, so the next step will be trying | + | As the automatization of the Windows build script currently works (only the last step which is using Visual' |
- | Once I get the project running, I can begin the automatization of the building. As in the windows one, I'll backtrack my steps to code it. Then I shall use the snap and AppImage to create the basic Appdir and Snap. I've noticed there is a similar process in the current version | + | =====Coding |
- | =====Packaging | + | I have only built the project for windows, so the next step will be trying to build it for Linux. Best should be using Ubuntu as a distro since that is what will be used in the Linux Github runner. So I'll probably use WSL or an equivalent to try out the installation. |
- | As the automatization of the Windows build script currently works (only the last step which is using Visual' | + | Once I get the project running, I can begin the automatization of the building. As in the windows one, I' |
=====Packaging the Linux Install (Week 5-6)===== | =====Packaging the Linux Install (Week 5-6)===== |
