Both sides previous revisionPrevious revision | Last revisionBoth sides next revision | ||
gsoc:plan2022 [2022/06/11 12:01] – [Packaging the Windows install (Week 1-2)] cristik24 | gsoc:plan2022 [2022/06/11 12:02] – [Coding of the Linux script (Week 3-4)] cristik24 | ||
Line 11: | Line 11: | ||
I have only built the project for windows, so the next step will be trying to build it for Linux. Best should be using Ubuntu as a distro since that is what will be used in the Linux Github runner. So I'll probably use WSL or an equivalent to try out the installation. | I have only built the project for windows, so the next step will be trying to build it for Linux. Best should be using Ubuntu as a distro since that is what will be used in the Linux Github runner. So I'll probably use WSL or an equivalent to try out the installation. | ||
- | Once I get the project running, I can begin the automatization of the building. As in the windows one, I'll backtrack my steps to code it. Then I shall use the snap and AppImage to create the basic Appdir and Snap. I've noticed there is a similar process in the current version of Librecad in \href{https:// | + | Once I get the project running, I can begin the automatization of the building. As in the windows one, I'll backtrack my steps to code it. Then I shall use the snap and AppImage to create the basic Appdir and Snap. I've noticed there is a similar process in the current version of Librecad in [[https:// |
=====Packaging the Linux Install (Week 5-6)===== | =====Packaging the Linux Install (Week 5-6)===== |
