start [2019/04/28 17:01] – created lordofbikes | start [2020/06/16 10:36] – dushyantvyasg007 | ||
- | **Welcome to the LibreCAD | + | **Welcome to the LibreCAD |
- | This is the landing page for https://dokuwiki.librecad.org/ | + | It is assumed you are familiar with the [[https://librecad.org|LibreCAD website]] overview of: |
+ | * [[https:// | ||
+ | * [[https://librecad.org/ | ||
- | ===== Sub Level 1 ===== | + | More detail is available in this wiki and the user manual described in the next section. |
- | Subsection 1 | + | |
- | ==== Sub Sub Level ==== | + | {{start: |
- | Content | + | |
- | ===== Sub Level 2 ===== | + | |
- | Subsection | + | |
- | ==== Sub Sub Level ==== | + | |
- | Content | + | |
+ | **LibreCAD** has a **free software** [[https:// | ||
+ | ===== LibreCAD capabilities ===== | ||
+ | * Partial support of Autodesk DWG format (importing only). | ||
+ | * Support of Autodesk DXF open format (import and export). It is LibreCAD main format. | ||
+ | * Export in PDF format and image format (PNG, SVG, bitmap). | ||
+ | * Support of MakerCAM SVG format. **To be confirmed** | ||
+ | * Line, circle, arc, polyline, spline. | ||
+ | * Entity modification: | ||
+ | * Cartesian and polar coordinate systems. | ||
+ | * Local coordinates system: you can choose a new origin to input ang get coordinates. | ||
+ | * Snap functions to accurately draw with end points, middle points, center of arcs, intersection of lines. | ||
+ | * Hatch. | ||
+ | * Blocks can be created and inserted. | ||
+ | * Library to manage standard components through blocks (screw, windows, etc.). | ||
+ | * Text annotation. | ||
+ | * Dimensions: linear dimension aligned with feature, radius, diameter, leader. | ||
+ | * Layer management: toggle for visibility and for printing, entity properties driven by layer properties (color, line width, type of line). | ||
+ | * Print to a chosen scale. | ||
+ | * Toolbars can be customized. | ||
+ | * Several actions can be made through the command line. | ||
+ | * Plugins developed to ease some tasks. | ||
+ | * User Interface available in several languages. |
