start [2019/06/12 20:59] – Licence fa201 | start [2020/06/16 10:36] – dushyantvyasg007 | ||
- | **This page is under work** | + | ====== Introduction ====== |
+ | **Welcome to the LibreCAD Wiki for tutorials and how-to!** | ||
- | ====== Introduction to LibreCAD | + | It is assumed you are familiar with the [[https:// |
- | **Welcome to the LibreCAD wiki!** | + | * [[https:// |
+ | * [[https:// | ||
- | This is the landing page for https:// | + | More detail |
- | LibreCAD is a **free and open source 2D CAD** application. Its purpose is to provide a free drawing solution for hobbyists and even professionals. Those interested in LibreCAD | + | {{start: |
- | ===== Licence ===== | + | **LibreCAD** has a **free software** [[https://github.com/LibreCAD/LibreCAD/blob/master/ |
- | **LibreCAD | + | |
- | You will find more information on the license and Copyrights in the [[https://librecad.readthedocs.io/en/latest/appx/licenses.html|User Manual Appendix]]. | + | |
===== LibreCAD capabilities ===== | ===== LibreCAD capabilities ===== | ||
* Partial support of Autodesk DWG format (importing only). | * Partial support of Autodesk DWG format (importing only). | ||
- | * Support of Autodesk | + | * Support of Autodesk DXF open format (import and export). It is LibreCAD |
+ | * Export in PDF format and image format (PNG, SVG, bitmap). | ||
+ | * Support of MakerCAM SVG format. | ||
* Line, circle, arc, polyline, spline. | * Line, circle, arc, polyline, spline. | ||
- | * Entity modification: | + | * Entity modification: |
+ | * Cartesian and polar coordinate systems. | ||
+ | * Local coordinates system: you can choose a new origin to input ang get coordinates. | ||
+ | * Snap functions to accurately draw with end points, middle points, center of arcs, intersection of lines. | ||
* Hatch. | * Hatch. | ||
* Blocks can be created and inserted. | * Blocks can be created and inserted. | ||
Line 26: | Line 33: | ||
* Layer management: toggle for visibility and for printing, entity properties driven by layer properties (color, line width, type of line). | * Layer management: toggle for visibility and for printing, entity properties driven by layer properties (color, line width, type of line). | ||
* Print to a chosen scale. | * Print to a chosen scale. | ||
- | * Tool bars can be customized. | + | * Toolbars |
* Several actions can be made through the command line. | * Several actions can be made through the command line. | ||
* Plugins developed to ease some tasks. | * Plugins developed to ease some tasks. | ||
* User Interface available in several languages. | * User Interface available in several languages. | ||
